How To Give Dos More Than 4 Partitions
Getting old software/games running on older hardware.
Postby GabrielKnight123 » 2019-3-13 @ 18:27
I read here before its possible to enable more than 4 partitions for Dos im hoping to have about 10 partitions at 2GB each or more or to use one/two partitions at 5GB or more if possible. Its just for Dos and Win 3.11 and I bet people here think 4 partitions isnt enough too.
GabrielKnight123
Re: How To Give Dos More Than 4 Partitions
Postby clueless1 » 2019-3-13 @ 19:18
IIRC, DOS 7 + a motherboard with BIOS support for >8.4GB will solve all your problems. With these two prerequisites, you won't be limited to 8.4GB total capacity or 2GB partition size.
User avatar
clueless1
Postby GabrielKnight123 » 2019-3-13 @ 19:59
I have a 486DX2 66MHz and a GMB-486UNP mobo so I have to use DDO to get the full HDD size over the default Bios 504MB is there another way with Dos 6.22?
GabrielKnight123
Postby keenmaster486 » 2019-3-13 @ 20:08
Use EZBIOS.
But also, FreeDOS FDISK is a better partition manager and lets you make more than one primary DOS partition instead of having to make an extended partition with logical drives.
http://classictechnology.herokuapp.com
Main desktop: Pentium MMX/200 (Socket 7), SB16, 64MB RAM, S3 Trio64V2/DX, Windows 95 OSR2
Laptops: IBM Thinkpad A20m (PIII 700MHz, 512MB RAM), Toshiba Satellite Pro 460CDT (Pentium MMX/166, 64MB RAM)
User avatar
keenmaster486
Postby kjliew » 2019-3-14 @ 04:24
MBR - the disk partition scheme for the last 30+ years can only support 4 primary partitions. To overcome this limitation, you need to make one of the primary partition into extended partition, then you can create theoretically unlimited logical drives out of the space allocated for the extended partition, but for DOS the limit will be the last assignable drive letter Z:
DOS with legacy BIOS will not support GPT, which allows up to 128 primary partitions. If you are adventurous, then you can research further on GRUB4DOS capabilities to boot off GPT partition and the creation of hybrid MBR/GPT disk partition scheme.
kjliew
Postby yawetaG » 2019-3-14 @ 06:47
kjliew wrote:MBR - the disk partition scheme for the last 30+ years can only support 4 primary partitions. To overcome this limitation, you need to make one of the primary partition into extended partition, then you can create theoretically unlimited logical drives out of the space allocated for the extended partition, but for DOS the limit will be the last assignable drive letter Z:
This. Create one primary partition + 1 extended partition, which you split into 9 logical drives.
yawetaG
Postby dr_st » 2019-3-14 @ 07:47
I think DOS6 has a 7.something gig limit anyways.
No one in hell needs >4 partitions just for DOS and 3.11. And if your DOS game collection is >7GB, use Win98 DOS.
User avatar
dr_st
Postby jmarsh » 2019-3-14 @ 08:08
dr_st wrote:I think DOS6 has a 7.something gig limit anyways.
Without a drive overlay, yes.
jmarsh
Return to Software
Who is online
Users browsing this forum: Damaniel, odd144 and 1 guest
