First post, by bergqvistjl
- Member
Specs
Jetway J-542B with AMD K6-2 400.
32MB RAM
ATI Rage Pro 128
MS-DOS 6.22 (Fresh install)
When I run GP2, when I load the track, it crashes with a DOS/4GW error:
https://i.imgur.com/idWaKrn.jpg
When I load the game with DOS-32A instead, It crashes in the same place, with this:
https://i.imgur.com/Ch8kheN.jpg
Any ideas?
Do you think stability would improve if I upgraded to a K6-2+ 500Mhz CPU (and used the patched bios for this mobo to enable write-allocation, from here: http://web.inter.nl.net/hcc/J.Steunebrink/k6plus.htm)
It was working fine on a a system with a 1Ghz P3 Coppermine (Jetway 993AN motherboard, rest of the specs identical).
UPDATE:
Still with the 400Mhz CPU, I applied the patched BIOS, and the game no longer crashed.
