First post, by MrD
Hi, I am trying to run the game Get Lost by Tom Bombadil's Software Emporium & House of Curiosities
Full version available here: http://www.sleepfuriously.com/getlost/getlost.html
The game runs perfectly in DOSBOX but I can't get it to run on my real MSDOS hardware.
I can configure the sound fine using the SETCFG.EXE and I can hear the sound okay.
When I start the game with GETLOST.EXE, I get the intro sequence with the house and the title screen with music in the background.
It's supposed to fade to black and show the level select, but the game exits after the fade to black with the error Tom says Whoops 21020. If I disable my sound card in the options or remove it entirely, I get the error Tom says Whoops 8002
I also get 21020 if I run getlost.exe after holding right shift after booting.
Does anybody have any advice please? 😀 the only other mention of Get Lost that I can find on this forum is my own post from six years ago diagnosing a broken sound card (which I've since replaced 😀 )
autoexec.bat
@ECHO OFF
LH /L:0;2,45488 /S C:\DOS\SMARTDRV.EXE /X
PROMPT $P$G
PATH C:\DOS
LH /L:2,35536 C:\DRIVERS\MOUSE\MOUSE.COM
LH /L:1,6384 DOSKEY
SET TEMP=C:\DOS
MODE CON CODEPAGE PREPARE=((437) C:\DOS\EGA.CPI)
MODE CON CODEPAGE SELECT=437
LH /L:2,17856 KEYB UK,,C:\DOS\KEYBOARD.SYS
LH /L:2,27952 C:\DOS\MSCDEX.EXE /D:MSDC001
SET BLASTER=A220 I5 D1 T4
C:\DRIVERS\YAMAHA\SETUPSA.EXE /S
config.sys
DEVICE=C:\DOS\HIMEM.SYS
DEVICE=C:\DOS\EMM386.EXE RAM HIGHSCAN I=B000-B7FF
BUFFERS=15,0
FILES=30
DOS=HIGH,UMB
LASTDRIVE=X
FCBS=1,0
STACKS=0,0
DEVICEHIGH /L:1,12048 =C:\DOS\SETVER.EXE
COUNTRY=044,,C:\DOS\COUNTRY.SYS
DEVICEHIGH /L:1,18112 =C:\DOS\DISPLAY.SYS CON=(EGA,,1)
DEVICEHIGH /L:3,20688 =C:\DRIVERS\CD\ACTCD.SYS /D:MSCD001
SHELL=C:\COMMAND.COM /E:1024 /P
mem /a/c/p
Name Total = Conventional + Upper memory
MSDOS 14029 (14k) <--- 0
HIMEM 1168 (1k) <--- 0
EMM386 3120 (3k) <--- 0
COMMAND 3696 (4k) <--- 0
SETVER 624 (1k) 0 <---
DISPLAY 8336 (8k) 0 <---
DOSKEY 4144 (4k) 0 <---
SMARTDRV 29024 (28k) 0 <---
MOUSE 14656 (14k) 0 <---
KEYB 7856 (8k) 0 <---
MSCDEX 27952 (27k) 0 <---
ACTCD 17120 (17k) 0 <---
Free 681952 (666k) 633152 (618k) 48800 (48k)
Type of memory Total Used Free
Conventional 655360 22208 633152
Upper 158512 109712 48800
Reserved 393216 393216 0
Extended (XMS)* 65901776 2675920 63225856
Total memory 67108864 3201056 63907808
Total under 1 mb 813872 131920 681952
Total Expanded (EMS) 33947648
Free Expanded (EMS)* 33554432
Largest executable program size 633056
Largest free upper memory block 18544
Available space in High Memory Area 4464
MSDOS is resident in the high memory area.
motherboard: p5i430tx titanium ib
cpu: pentium mmx (configurable 100mhz to 233mhz in 33mhz increments)
Actima (generic?) cdrom ide driver
Yamaha Audician 32 Plus ISA card with a Yamaha OPL YMF718-S chip
generic oem serial mouse driver
S3 Virge pci graphics
64mb RAM as 4x16mb simms
