Desqview, QEMM and 4DOS?
Getting old software/games running on older hardware.
Postby Dacobi » 2019-4-02 @ 11:50
Hi
I'm currently trying to setup an old DOS PC with 4dos, qemm and desqview.
I have them all installed, but when I change the SHELL in config.sys to 4DOS.COM
desqview can't start dos shells. I get an error "File Not Found"
Does anyone know if this can be fixed?
/Jacob
Dacobi
Re: Desqview, QEMM and 4DOS?
Postby retardware » 2019-4-02 @ 12:00
set comspec=c:\4dos.com /p /e:1024
set /e:xxx to an environment size xxx that is reasonable for your applications. DOS defaults to 160, which is ridiculously small.
retardware
Postby Dacobi » 2019-4-02 @ 12:12
I don't understand,
set comspec, instead of setting SHELL?
Dacobi
Postby Dacobi » 2019-4-02 @ 13:06
Nevermind, I got it working. Thanks :)
Dacobi
Postby Dacobi » 2019-4-02 @ 13:11
Ok, I have another problem now.
If I try to open a DOS shell in a window (ie DOS 128k)
I get an error that "Program is to big to fit in memory"
Is this because 4dos.com is to big?
Opening a "Big DOS" Shell works fine
Dacobi
Postby Jo22 » 2019-4-03 @ 11:03
I don't know for sure, since I ahven't used 4DOS that much in the past, but generally speaking,
yoo can change/edit/rename that DESQView menu item so the DOS window has got more than 128KB. :)
User avatar
Jo22
Postby Dacobi » 2019-4-03 @ 11:16
Jo22 wrote:generally speaking, yoo can change/edit/rename that DESQView menu item so the DOS window has got more than 128KB. :)
Which file do I need to edit?
Or is there a setup for this?
Dacobi
Postby Dacobi » 2019-4-03 @ 11:22
Dacobi wrote:Which file do I need to edit?
Nevermind, I'm an idiot :)
Dacobi
Postby Dacobi » 2019-4-03 @ 11:35
The problem I have now is that ANSI.SYS doesn't work with the 4dos prompt command in DesqView.
Anyone know how to fix this?
Dacobi
Postby Dacobi » 2019-4-03 @ 12:46
Ok, figured it out to using the dvansi.com command via an iff statement in 4start.bat
Dacobi
Return to Software
Who is online
Users browsing this forum: No registered users and 2 guests
