Reply 20 of 22, by Dacobi
Thanks for the answer.
I actually did something like this with pipes many many years ago.
I made a GUI program to run a cli cdrom burner tools in Linux.
But here I only piped the output and then used system() for the cli command.
So I think I understand the windows example you linked.
The problem seems to be to find docs regarding this process in DOS/C
Everything on Google is Windows oriented.
