MS DOS 6.22 / 7 HDD performance enhancement.
Getting old software/games running on older hardware.
Postby ruthan » 2019-5-07 @ 19:05
Is somewhere good tutorial how to enhance pure DOS HDD / SDD performance on modern PATA / SATA controllers / devices?
I always lived with no DMA - 2 MB/s, i find some driver on Rayers pages i tried it with my X58 machine, but i never was able to make it working. But would like to learn this.
Now i have some Super Socket 7 Cyrix machine and copy something which can be done in windows 98 in 2 times, take tens of minutes, yes im using some slimer 3GB HDD, but its still too slow even for it..
BTW it there good SMART utility for DOS or Windows 98? Something like Crystal Disk info for modern OSes?
Rayer has at least good testing utility RawCopy to test speed.
I never liked SmartDrive, its eating too much memory and i thing that its old and there better alternatives.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough HW.
User avatar
ruthan
Location: Schwarz Wald-from France to Ukraine, from Denmark to Austria. Celts+German+Slavs melting pot.
Re: MS DOS 6.22 / 7 HDD performance enhancement.
Postby 1541 » 2019-5-07 @ 19:20
Did you try "UltraDMA Drivers for DOS"
http://www.ibiblio.org/pub/micro/pc-stu ... udma70.zip
This has to be loaded via config.sys
DEVICEHIGH=C:\DOS\UDMA.SYS
and enables UDMA (if available).
I can get almost 33MB/s on my old retro system (UDMA Mode 2)
LOAD"$",8
User avatar
1541
Postby GigAHerZ » 2019-5-07 @ 19:28
There's this XHDD/XDVD/UHDD/UDVD driverpack for dos, supporting DMA and buffers in XMA.
User avatar
GigAHerZ
Postby Jo22 » 2019-5-10 @ 06:08
(Edit: Small edit. Line with question removed, as I have no desire being sued. ;) )
I guess I shouldn't mention this, but I vaguely recall there once was a unlovely conflict with one author of the accelererated drivers.
Edit: Never mind, sorry. :( That's not the right place for that kind of discussion, I suppose.
viewtopic.php?f=5&t=58177 , viewtopic.php?f=61&t=57291
User avatar
Jo22
Postby Fusion » 2019-5-10 @ 17:36
UDMA drivers for DOS? I'm gonna have to try these out for sure!
P3 800 | 512MB PC100| PCI V3 3000 16MB @ 195/195 | CT4780 SB Live! Value| WinME
P3 450 | 128MB PC100| AGP TNT2 Pro 32MB | CT4170 SB16 | MS-DOS 7.10
A64 2.4 | 2GB DDR1 | PCI-E Radeon X800XT @ 575/575 | Win2K
User avatar
Fusion
Postby ruthan » 2019-5-13 @ 16:57
I tried udma70.zip with my Socket 7 machine and tested it with Rayers rawcopy benchmark and its working. 9 MB/s instead of 2 MB/s
User avatar
ruthan
Postby dr_st » 2019-5-13 @ 18:09
Cool! Two questions:
1. How much memory (conventional/upper) does the driver itself take?
2. Does it in any way conflict with Win9x DMA (if Windows is loaded after the driver)?
Oh, hell, I have a Win9x system here now! Might as well test it myself. :cool:
User avatar
dr_st
Postby dr_st » 2019-5-13 @ 19:40
So the answers are simple:
dr_st wrote:1. How much memory (conventional/upper) does the driver itself take?
600-something bytes. Nothing, really. Amazing.
dr_st wrote:2. Does it in any way conflict with Win9x DMA (if Windows is loaded after the driver)?
Unfortunately, yes. Immediately upon loading, Windows complains that UDMA.SYS is forcing compatibility mode and reduces performance, and then programs start crashing. So you should not run Windows if this driver is loaded, and it also seems that it cannot be unloaded. Good for DOS only systems or those with multiple CONFIG.SYS menu options.
User avatar
dr_st
Postby johnsonlam » 2019-5-15 @ 07:55
Please stop using UDMA.SYS, it's unstable and may ruin your data, I've another new post for the latest version XHDD.SYS, please check my post.
http://optimizr.dyndns.org/dos/drivers.html
User avatar
johnsonlam
Postby dr_st » 2019-5-15 @ 08:40
You're welcome to attach a link to your post; it would make it easier to find it. :)
User avatar
dr_st
Postby johnsonlam » 2019-5-18 @ 04:16
Done :)
User avatar
johnsonlam
Postby ruthan » 2019-5-19 @ 14:09
I looked on link above, i dont see what was wrong with UltraDMA Drivers for DOS, package.
In documentation is how to set in for Realmode and Protected mode.. JEMM, but what about old EMS mode? Its still compatible?
User avatar
ruthan
Return to Software
Who is online
