Panzer General 1 installation problem with XMS
Getting old software/games running on older hardware.
Postby Musti » 2019-5-11 @ 06:47
Hello everyone,
i want to install the game Panzer General 1 on a Windows 98 SE guest system with PCem. The installation is not starting, because it can't detect the XMS memory. If i write MEM into the DOS prompt i get the following informations about the XMS memory:
Code: Select all
    Total: 65.472K
    Occupied: ?
    Free: 129.824K
Is XMS disabled in my system and if yes how can i activate it? I have read about the file HIMEM.SYS which is probably related to XMS. But i couldn't find it in my C: drive. Is that file not integrated in Windows 98 SE? This is the content of my config.sys file:
Code: Select all
device=C:\WINDOWS\COMMAND\display.sys con=(ega,,1)
Country=049,850,C:\WINDOWS\COMMAND\country.sys
DEVICEHIGH=C:\DOS\OAKCDROM.SYS \D:MSCD001
User avatar
Musti
Re: Panzer General 1 installation problem with XMS
Postby akula65 » 2019-5-11 @ 14:14
I don't have any experience with PCem, but in an honest-to-goodness-not-emulated Windows 98 SE installation with 256 MB of memory, this is what I get with the MEM command:
Code: Select all
Memory Type        Total       Used       Free
Conventional          640K        68K       572K
Upper                   0K         0K         0K
Reserved                0K         0K         0K
Extended (XMS)     65,472K          ?   260,640K
Total memory       66,112K          ?   261,212K
Total under 1 MB      640K        68K       572K
Total Expanded (EMS)                   64M (67,108,864 bytes)
Free Expanded (EMS)                    16M (16,777,216 bytes)
Largest executable program size       572K (586,160 bytes)
Largest free upper memory block         0K       (0 bytes)
MS-DOS is resident in the high memory area.
My C:\CONFIG.SYS is as follows:
Code: Select all
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICE=C:\WINDOWS\EMM386.EXE
So your MEM output suggests that you DO have XMS memory somehow, possibly through PCem. Perhaps your question should be asked in the PCem forum. I would imagine this is a fairly common problem if PCem substitutes some sort of memory managers for the Win98 SE memory managers.
User avatar
akula65
Postby Musti » 2019-5-11 @ 14:16
Thank you for your answer, i will try that.
User avatar
Musti
Postby Musti » 2019-5-12 @ 17:58
I have found a solution. I made a copy of the MS-DOS prompt on my Desktop. Right click on it --> Properties --> Memory --> changed XMS from automatic to a set value and the installation of Panzer General started.
User avatar
Musti
Postby Stiletto » 2019-5-13 @ 17:56
Wrong forum. Moved.
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Return to Software
Who is online
Users browsing this forum: realoldguy23 and 2 guests
