First post, by simprato
hi
I'm italian so, sorry for my english.
I've a strange problem with my retropc.
I ever want to use Windows ME because of more faster boot, better USB support, ecc.
But my problem is when LAN Card is ON fps drops noticeable. If i disable the card from device manager, all works perfect
I' ve tried with Win98SE and the problem with this OS don't exist.
Changing card (and drivers) don't resolve. Fresh install of WinME without any program/upgrade is the same.
Obviously this in ever game is noticeable.
Example:
Tomb Raider II @ 1280x960x16 with 98 or LAN off in WinME: stable 30fps, with lan on winME: 30-25-21-22-28-30-30-30-30-21-25...every 5-8 seconds fps drops
Specs are:
ABIT BF6 (i440BX)
Pentium III 700Mhz (100FSB) Coppermine on S370 adapter
2x256Mb PC133 C3
3DFX Voodoo3 2000 AGP @166mhz
Sound Blaser Live! Value
HPT370A PCI IDE ATA-100
3COM 3C905-TX-M LAN
Maxtor D740X-6L 20GB HDD
DirectX 8.2
Don't write "use win98" because is too simple. Anyone who is a fan/user of WinME had notice this problem?
No conflicts with IRQ in system info, PCI are populated by reading manual
I've also tried in other 2 motherboards, one with 815E chipset and the other, VIA 694T. Same CPU, Video, Card ecc.
