Always freezes after Chipset driver installation
Getting old software/games running on older hardware.
Postby Lazar81 » 2019-6-06 @ 20:50
Hello,
I don't know what to do anymore. I installed Windows 98 se now 20 times or so... Everytime I install the Chipset driver I got freezes after booting.
I am using a Chaintech 6via5t. As hdd I installed a SSD with a sata to ide adapter.
Everything is running ok - but as soon as I have installed the Chipset driver it crashes directly after booting.
The Chipset driver package is the Hyperion 4in1 435.
Lazar81
Re: Always freezes after Chipset driver installation
Postby cyclone3d » 2019-6-06 @ 21:49
Exactly which SATA to IDE adapter are you using? Pics?
What are the rest of the system specs?
User avatar
cyclone3d
Postby Lazar81 » 2019-6-06 @ 21:53
Well ... Looks like I have found the problem. I think the adapter does not support dma mode for hard drive. Pity
Lazar81
Postby Lazar81 » 2019-6-11 @ 19:27
So here we are again. And I solved the Problem. It was the adapter that prevented the usage of dma mode. I tried a bunch of other adapters and found the model from startech "40 pin ide to sata converter" working very well with SSD drive. And dma Mode is running out of the box.
Lazar81
Postby weldum » 2019-6-11 @ 22:05
these adapters are hit and miss
still, via drivers aren't very good either, i had a lot of problems with post-2000 via chipsets and 9x/ME
Ohh, the humanity :depressed:
386SX 25-C3 800-P3 900-Atom 1.6-C-D 2.13-P4 2.26-P4HT 3.0-P-DC 1.6-AFX 2.6-FX 3.3
User avatar
weldum
Postby Lazar81 » 2019-6-12 @ 05:44
weldum wrote:these adapters are hit and miss
After all there were no driver issues. I installed the Hyperion 4in1 4.35 (it seems to be the most stable with win9x and my hardware) and everything runs fine. It was obviously the adapter, that couldn't manage the dma. So looks like I have a hit now. I used startech products before. I find them sometimes a little bit expensive - as it is now for this adapter - but I never had any problems with startech. Although I read, that this new adapter wouldn't support dma for very old drives. Whatever that means...
Lazar81
Return to Software
Who is online
Users browsing this forum: No registered users and 2 guests
