Wolfenstein 3D Movement Issues
Getting old software/games running on older hardware.
Postby athlon-power » 2019-9-06 @ 18:45
As much as I love the id-Style 2.5D games, there's one big problem I have with them: whenever your mouse moves forwards, you move forwards. I've never understood this, as it cannot be disabled via the game itself. You have to find some sort of external means to disable this. In DOOM, Heretic, and a few other games, using an application called NOVERT will disable the vertical mouse movement, allowing you to be able to turn without being thrown forwards and backwards.
How was this even a good idea, even when the games were made? In order to keep moving forwards, you'd need to keep pushing your mouse forwards until it hit the end of the mousepad, pick it up, and then begin moving forwards again. It's not useful, even on its own. It's just a very irritating way of making turning around with a mouse harder. In some games, like DOOM, the movement is small enough to sort of get used to, but in Wolfenstein 3D, you can turn to the left or roght, and if your mouse moves forward a centimeter, you will go a few feet in that direction. The problem is that, when using NOVERT, Wolfenstein will detect a constant forwards movement for some reason, causing the main menu to rapidly switch between the options upwards.
How do I disable this forward mouse movement in Wolfenstein 3D? Should I just grab a non-important mouse and rip the vertical roller out of it? I mean, at this rate, I'm tempted to. Also, could somebody please explain why the developers did this? It honestly makes no sense to me.
User avatar
athlon-power
Re: Wolfenstein 3D Movement Issues
Postby derSammler » 2019-9-06 @ 18:53
I don't think any of these 2.5D games were ever meant to be played with a mouse. Everyone I know (myself included) play these using the keyboard.
It may work well with a trackball, however.
derSammler
Postby Caluser2000 » 2019-9-06 @ 19:04
derSammler wrote:I don't think any of these 2.5D games were ever meant to be played with a mouse. Everyone I know (myself included) play these using the keyboard.
^^^^ What he said.
User avatar
Caluser2000
Postby Blzut3 » 2019-9-07 @ 04:56
While I don't doubt the second sentence, the first sentence is easy to disprove just by watching the demos in Doom. Even Wolf3D's demos look like they're recorded with a mouse.
They must have thought that scheme made sense since it continues even into Quake where turning on modern mouse look is possible but the default is to move forward and backwards. Perhaps even stranger there since the demos use mouse look all the time.
Blzut3
Postby Caluser2000 » 2019-9-07 @ 06:10
Try playing wolfenstien on machines at the time it was release. Mice did not enhance the experiiance I con asure you. Put two players on machines exactly the same the guy on thevkeyboard will piss all over the guy with the mouse
User avatar
Caluser2000
Postby Calvero » 2019-9-07 @ 15:37
I think you can see one of the developers of Wolfenstein 3D, John Romero, play the game with a mouse in this video: https://www.youtube.com/watch?v=_hHTCHSw9Gk
Calvero
Postby rmay635703 » 2019-9-07 @ 15:46
The proper use of the mouse was in Duke 3d where it aimed and the keyboard controlled the rest
User avatar
rmay635703
Postby aleksej » 2019-9-08 @ 16:13
Not a big deal if you moves slightly in vertical axis in such trapless game - without pitfalls, crushers and etc. Also you can't record your moves in demo, at least in original DOS game. So no catwalk and speed demos and nobody cares. However you may use DOS mouse driver with ability to set sensitivity for X/Y axis independetly. ctmouse do it well.
aleksej
Return to Software
Who is online
Users browsing this forum: Caluser2000, kolderman and 3 guests
