AMD 5x86 P75 - Win98 or Win98?
Getting old software/games running on older hardware.
Postby AlessandroB » 2019-9-09 @ 20:42
Wich os is better for this kind of system? have 32Mb ram but i can reach 64Mb, trident 9400 and vlbus IDE controller.
Win98SE will be too slow without advantage respect win95 on this computer?
Tnks.
AlessandroB
Re: AMD 5x86 P75 - Win98 or Win98?
Postby Caluser2000 » 2019-9-09 @ 21:01
Go Win98 and remove all the extra unneeded crap of it. The better USB support is worth it. Failing that Win95 OSR 2.5. Ignore the original Win95 as it has no Fat32 support.
User avatar
Caluser2000
Postby AlessandroB » 2019-9-09 @ 21:52
My 486 not have usb port and i can't add.
AlessandroB
Postby Caluser2000 » 2019-9-09 @ 22:07
Windows 95 OSR 2.5 then
User avatar
Caluser2000
Postby chinny22 » 2019-9-10 @ 10:55
2nd for Win95 2.5, any 486 will still spend most its gaming time in dos anyway
User avatar
chinny22
Postby AlessandroB » 2019-9-13 @ 20:00
And what function can windows95 have on a 486 if it is used for 90% in DOS? I would have used it to transfer files more comfortably than with DOS ... but for that also win3.11 can be enough
AlessandroB
Postby Intel486dx33 » 2019-9-13 @ 23:42
I have an AMD 5x86 with 32mb of ram and a CF card for hard-drive.
PCI video card 4mb.
It is running Win95b and it SUCKS !
It performs okay but will NOT play back MP3’s very well.
A little choppy.
I definitely would NOT put Win98 on it.
User avatar
Intel486dx33
Postby Caluser2000 » 2019-9-13 @ 23:47
AlessandroB wrote:And what function can windows95 have on a 486 if it is used for 90% in DOS? I would have used it to transfer files more comfortably than with DOS ... but for that also win3.11 can be enough
Win 3 will be leaner. You can also just go the complete Dos route using the ftp client from the mTCP suite of programs. Al you need s packet driver for your network card.
User avatar
Caluser2000
Postby Caluser2000 » 2019-9-13 @ 23:55
Intel486dx33 wrote:I have an AMD 5x86 with 32mb of ram and a CF card for hard-drive.
PCI video card 4mb.
A little choppy.
Hardly surprising at all. You can strip Win95b down a bit though.
User avatar
Caluser2000
Postby mothergoose729 » 2019-9-13 @ 23:56
AlessandroB wrote:Wich os is better for this kind of system? have 32Mb ram but i can reach 64Mb, trident 9400 and vlbus IDE controller.
Tnks.
I wouldn't bother with windows on a 486. I would just use a compact flash card for storage in a removable bay, and transfer files and games to it with a PC. Windows 3.11 or a DOS shell can be used for more convenient file management if you need it. The only reason to get windows 95 IMO is if you plan on doing networking or surfing the net... or of course for windows games, which will all run like molasses on a CPU like that anyhow.
mothergoose729
Postby AlessandroB » 2019-9-14 @ 07:27
my fileserver run Win10, can i access it using Win3.11 or Win95 on SMB?
AlessandroB
Postby GigAHerZ » 2019-9-14 @ 09:50
You need to enable SMB1 support on Win10, then you can.
User avatar
GigAHerZ
Postby AlessandroB » 2019-9-14 @ 10:47
i take a look how to do soon as i can tnks for now
AlessandroB
Postby AlessandroB » 2019-9-15 @ 18:02
GigAHerZ wrote:You need to enable SMB1 support on Win10, then you can.
Also between w3.11 and win10
AlessandroB
Postby GigAHerZ » 2019-9-15 @ 19:28
There's nothing to enable in w3.11, as it only knows the first version, nothing else...
User avatar
GigAHerZ
Postby AlessandroB » 2019-9-15 @ 20:10
you mean that there is not possibilities from windows 3.11 to see a samba shared folder on windows10?
AlessandroB
Postby GigAHerZ » 2019-9-16 @ 05:23
@AlessandroB, there is - you need to enable SMB1 on Win10. By default SMB1 is turned off, as it's old and full of bugs and security flaws.
User avatar
GigAHerZ
Postby appiah4 » 2019-9-16 @ 08:41
Well, between Win98 and Win98, I'd definitely go for Win98.
A500:+512K|ACA500+|C1084S
i386:Am386SX-25|4M|TVGA9000B|ES688
i486:U5S-33|8M|GD5428|YMF719|MUNT-Pi
i586:P133|32M|T64+/MX2|V1|CT3980/32M|SD-35
i686:K6-2/400|64M|V2/SLI|CT4500/32M
S370:P3-1200|384M|GF4Ti4200|MX300
S754:A3700+|2G|X1950PRO|SB0350
User avatar
appiah4
Postby feipoa » 2019-9-19 @ 03:26
If you aren't going to use any games or other software in Windows, how about MS-DOS 6.22 and another partition with NT 3.51? I find NT 3.51 more stable and generally quicker than Win95c on a 486. WinNT4 feels a lot slower than NT 3.51 though. Apparently there is also a classic Windows NT/9x shell for NT 3.51 you could use.
User avatar
feipoa
Postby Caluser2000 » 2019-9-19 @ 07:59
I would'nt run New Shell on NT 3.5x. It's as buggy as all heck.
User avatar
Caluser2000
Next
Return to Software
Who is online
Users browsing this forum: Caluser2000 and 3 guests
