First post, by C0deHunter
- Member
https://www.scummvm.org/frs/scummvm/2.1.0/scu … win32-win9x.exe
When installed, it creates a folder called ScummVM on the desktop, containing the save and some configuration.ini files: very annoying.
Also, for MIDI emulation, it does not have the FuidSynth option on the MIDI drop-down menu. Phil clearly demonstrates this here:
https://www.youtube.com/watch?v=-356nSg6brA&t=4s
Under Win98 it is simply not there, whereas on Win7/10, the same ScummVM build (2.1.0) has this option.
See my original post with the issues that I encountered here:
https://forums.scummvm.org/viewtopic.php?f=2& … &p=87917#p87917
When I choose the sound as default, it doesn't produce any MT-32 emulation, and it defaults to OPL sound, and when I choose my AWE64GOLD as the sound card, it simply utilizes the AWE64 GOLD's Synth features (for MIDI and MT-32), and does not utilize MT-32 ROMs that I have placed in the ScummVM folder (since even when I remove the ROM files, it still has MIDI / MT-32 quality music, which I can clearly tell is created by its own MIDI synth instead)
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
