First post, by thrawn235
Hello,
I've been playing around with nc and while setting the file associations i noticed a problem.
NC uses the long filename it seems when sending the path-string to the application associated with the filetype.
most apps it seems cant handle long filenames.
Is there a way to set NC to use short names when in that scenario ?
