First post, by vorob
Take a look: https://youtu.be/fxD89sRMA48
I'm on Compaq Evo n400c with ATI Mobility M1 which is Ati Rage Pro actually.
Tried pure dos and windows 98, no luck
Reply 1 of 10, by root42
Maybe it's simply bad VGA compatibility in the Ati. Keen uses some sophisticated EGA and VGA features.
YouTube and Bonus
Reply 2 of 10, by ynari
root42 wrote on 2020-02-27, 09:35:
Yep, see https://gona.mactar.hu/DOS_TESTS/.
Try a different card, or use DOSBox, Keen 4-6 under it is indistinguishable from real hardware.
Reply 3 of 10, by root42
ynari wrote on 2020-02-27, 09:45:
Wow. That is one extensive matrix! Nice link!
YouTube and Bonus
Reply 4 of 10, by keenmaster486
There is a patch to fix ATI compatibility problems in Keen 4, 5, 6:
Re: Keen 4-5-6 choppy scrolling on EGA card
I flermmed the plootash just like you asked.
Reply 5 of 10, by K1n9_Duk3
Here's a more up-to-date version of my Keen 4-6 fixes. https://pckf.com/viewtopic.php?f=4&t=6192
I think you'll get better results with these updated patches. But the new code does introduce a slight delay after updating the screen, which may be noticeable on rather slow systems (286 and below). Just use whatever seems to work best on your system.
Reply 8 of 10, by ynari
leileilol wrote on 2020-02-28, 03:11:
losing that border is pretty distinguishable
Oddly, I don't remember a cyan border, so either I was being blind when doing a comparison (I did a Dosbox vs Real DOS Keen 6 A/B comparison), or it doesn't appear on my system. I'll have a look again tonight..
Reply 9 of 10, by K1n9_Duk3
That border is the "overscan" area. As far as I can tell, it's only visible on real hardware when connecting the monitor via a VGA cable, not DVI or HDMI or whatever. It's also possible that more modern CRT and/or LCD monitors adjust the position of the display so that the overscan area is not visible. But it's definitely visible on old CRTs.
