First post, by C0deHunter
Is there any?
Thanks!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 2 of 8, by C0deHunter
Thanks. Well, I came across this link:
https://anapan.525lines.moe/Game%20Wizard.htm
And download the 3rd link (Game Wizard 32 PRO 3.0 working installer files):
When I try running the installer from my hard drive, (install.exe), I get:
ERROR : This program can only be installed from a floppy drive.
So, I copied all of the 12 files to a real floppy diskette, and when I run the install, although I see the installation screen, and the path, when I press enter the installer just quits to the DOS prompt, with the following error:
Error: File not found.
Any idea why?
Reply 3 of 8, by derSammler
Yes, you need the original disk image due to copy protection. Also note that you'd better use the shareware version if you don't want this thread to get closed. What you found there is the registered version, which is still protected by copyright laws.
I've attached the 2.50 shareware version.
Reply 4 of 8, by zyga64
There is also Gamebuster 4 program. I tested it on 286 PC.
You can activate it pressing CTRL key 3 times. It can be useful for saving/loading in games which doesn't provide these functions itself.
Reason: removed cracked software
1) VLSI SCAMP /286@20 /4M /CL-GD5422 /CMI8330
2) i420EX /486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
3) i430FX /K6-2@400 /64M /Rage Pro PCI /ES1370+YMF718
4) i440BX /P!!!750 /256M /MX440 /SBLive!
5) iB75 /3470s /4G /HD7750 /HDA
Reply 5 of 8, by C0deHunter
Thanks, I tried GameBuster4, GameWizard 3, 2, shareware, etc. None worked on my system (see signatuare). The only one worked for me (worked EXACTLY like Action Replay, that I had many years ago on PC) was the INFINITY MACHINE! I was able to successfully use it with Bitmap brother's GOD, and it worked like a CHARM!
Reply 7 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
derSammler wrote on 2020-04-12, 15:06:
zyga64 wrote on 2020-04-11, 20:08:
Please do not link to or provide cracked commercial tools!
Thanks, took care of it
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 8, by zyga64
I wasn't aware that it was cracked software. Sorry !
