Reply 100 of 108, by Jo22
- l33t++
the3dfxdude wrote on 2021-06-25, 20:45:Shreddoc wrote on 2021-06-21, 00:17:ME's problem (standard intergenerational teething issues aside) is that it was an incremental, gap-filling release whose improvements were easily dismissed by contrast to the NT-based next gen that everybody knew was coming*. A quick wax, polish and tuning [ME] before swapping out the entire engine [XP].
Well, and even the WinME team at Microsoft seemed to hate it and wanted to move to NT5.1+ projects because that kernel was technically superior. It's actually a bit of a miracle ME wasn't cancelled given the tight schedule -- it pretty much did not make sense. It probably only happened because NT5 kept slipping and some boss wanted a product launch of windows for home users in 2000. I mean, look at XP on launch in 2001, still wasn't actually ready... so what home version could they really ship in 2000?
Hm. Maybe the MS people simply wanted to get rid of the whole 9x line altogether, so they could focus on one platform (Win CE excepted)? 😉
Anyway, I think that Me is/was interesting still and that it was a good thing to happen.
I mean, Win Me is/was literally a fusion of Windows 98SE and Windows 2000 - two of the most valued Windowses of the time.
Some people even nicknamed it Windows 98 Third Edition at the time.
That being said, Windows Me didn't have an easy start when it was launched.
It was primarily sold as an upgrade and had higher minimum requirements than 98SE.
Also, its OEM versions sometimes were dongled to a specific BIOS..
I experienced that myself in the early 2000s.
This totally took the fun out of it. Normally, you can swap the HDD or the motherboard and Win 98SE does at least boot up in safe-mode, but in case of Win Me..
Well, it didn't work. It even spit out an error message regarding the BIOS/PC being wrong, I remember.
Let's remember, this was before the days of online activation.
Back then, users were used to be able to install their Windows on any system and
a valid CD key was all that mattered.
That being said, Windows Me in the hands of an advanced user wasn't that bad at all.
Maybe that's why our modern experience with Me is better:
We have become experienced users with patience and wisdom.
By contrast, back then many users installed/uninstalled lots of software on a regular basis and didn't care about the effects this would have to the underlying OS.
Also, 9x drivers were still immature at the turn of the century and not aware of Win Me yet.
Windows 9x drivers consisted of a wild mix of 16-Bit/32-Bit code (DRV/VXD/WDM), often with DOS Real-Mode drivers (SYS/COM/EXE) included.
Unfortunately, Windows Me did delete Autoexec.bat and Config.sys during boot, which also broke the Windows 9x parts of a driver package: DOS utilities that initialized the hardware were never run in first place.
So all in all, the experience was pretty bad for some users. Comparably to Windows XP without Service Pack, maybe.
But that doesn't necessarily mean that the system is/was completely flawed.
Sure, it was quickly thrown together. But with parts from Windows 2000, the best MS OS at the time!
Hm. It's different to judge about Win Me, I think.
Because, it didn't run best in the era it was released.
But on the other hand, it ran kinda well with the hardware that was released afterwards.
See, Windows Me tends to run well with Windows XP (WDM) era hardware.
Pentium IV, Athlon etc. The kind of hardware that troubled Windoes 98SE a bit.
So are these "alternative facts" really fake ? 😉
cyclone3d wrote on 2021-09-01, 01:02:Shreddoc wrote on 2021-09-01, 00:36:cyclone3d wrote on 2021-08-31, 23:30:Did anybody you do Beta testing in Windows ME? back then it was very simple to sign up to have the Beta versions mailed to you from MS. I still have the CD zip folder they sent at one point. They also sent out some sticky-notes and I think a few other small things.
I did the same for 98SE and still have the final CD but it refuses to accept the CD key that was provided with it for some reason. It did work back in the day but when I tried to use it years later it wouldn't work.
Beta key expiration date -related, perhaps?
Maybe,but it still wouldn't work even with the date set way back so not sure.
Hm. Maybe the clock must be set to very narrow time frame?
I've done some experiments with older trial software in the past and some of them need to be run in a very small time frame,
spanning a few months only.
If the date was set too early, the program didn't run, either.
