First post, by buckeye
Patched with 1.3/1.31/1.32/1.33, do any of these break the option to enable cheats?
Tried the -devmode add on for the command line on the executable but no dice.
Yes I did modify/replace the "lua" file per the usual instructions.
Foxconn Q45M E8400 Core2 Duo 3GB DDR2 800 BFG Geforce 7950GT 512MB X-Fi Xtreme Music 500W XP SP3
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
Intel DH61CR i3 LGA-1155 8GB DDR3 EVGA 1050ti 4GB 480GB SSD 650W
Reply 1 of 2, by candle_86
It shouldn't at all
Phenom II X4 840T @ 4ghz - ASUS M3N72D-SLI - GTX 560 Ti- 4GB DDR2 1066 - 1TB HDD - Windows XP
Pentium 4 3.4C - MSI 865PE NEO2 - x850 XT PE - 2GB DDR 400 - 500GB HDD - Windows XP
Duron 1600 - ASUS A7N8X - 512MB DDR 266 - Radeon 8500 LE
Reply 2 of 2, by buckeye
Candle_86, you're right. I didn't realize the devmode.lua file I downloaded was in text format. Once I saved it in "lua" format all was fine.
