XCOPY problem
First post, by PlaneVuki
Hello,
C drive has an empty folder ABC123
D drive has folder ABC123 that contains files and other folders with files (D is a CD)
I want to use XCOPY from FreeDOS, I tried latest and older version, it gives same error:
>XCOPY D:\ABC123 C:\ABC123
Source path not found - \\D.\A.\
0 file(s) copied
>_
Whats going on? What is the problem?
I can copy exact same folder manually using COPY, but it is tedious. (creating all subfolders manually and using COPY command for each folder)
Thanks in advance.
