First post, by JonnyGators
I've been tinkering around with different hardware, trying to do things for various reasons. Or for no reason. I have a Pentium 4 machine that I tinker around with a lot, that is mostly used as a 98/XP dual boot machine. I had a spare HD module kicking around, and installed DOS 6.22 onto it with no problems, and would like to play around with getting Windows 3.1 on it, but I run into this strange problem.
Once I have DOS 6.22 installed, I put in the first disk for Windows 3.1 and run setup. Setup starts running with no problem, and I continue to have full use of the keyboard for the start of the setup process. But once I make the choice for express or custom setup, as soon as it goes on to the next step and starts copying the files from disk 1, keyboard functionality ceases to exist. The numberlock key no longer is able to be enabled or disabled (kept pressing this key to determine the exact moment the functionality breaks). This means that once it asks for disk 2, I can't press enter for it to continue. Well....I can press enter, but it won't do anything.
I'm using PS2 mouse and keyboard on this computer. I did try it with a USB as well for troubleshooting - exact same problem. Someone suggested something about usb compatibility modes playing a role even though I'm not using usb. I found no such settings for this in the BIOS settings to disable. I did try disabling USB altogether, but still got the same problem.
I suppose I don't really need Windows 3.1 on a Pentium 4, but still, this is driving me nuts, I see no reason this should break at this point, this should work.
Any ideas/suggestions for further troubleshooting of this problem?
