First post, by Warlord
- l33t
hey I tried to just boot a 486 DX2 with a floppy and run GODS and I get some Error Dos Error - Return Code AX=;
Tried searching for a solution
That is certainly not any kind of typical error.
To rule out the obvious: are you installing this game from original media? And have you been able to run other things on this 486?
Gods is that kind of game that just runs on everything, well with verry fast machines you just disable cache. 486 class machines totally do not need that.
What are your config.sys and autoexec.bat configuration and what dos version do you use?
The issue seemed to resolve itself when I found a iso of the game online, not the warez version I got from somwhere. I want to say that the warez version I had worked fine on all the other computers i tried it on.
I do have a wares version with two executables, on normal, and one with full invicibility cheat.
It should be very easy to spot which version you have:
And the biggest mystery, why did they release a version without copy protection ?
