First post, by egbertjan
I would like to play carmageddon under msdos 6.22 with my voodoo 1 card. With a voodoo 2 card I get it working fine. I have tried several glide2x.ovl files to get it working, but nothing helped. Maybe someone knows which glide2x.ovl I can use best for my voodoo 1 card. The glide2x.ovl that I use for my voodo 2 card works fine with my voodoo 1 card in tomb raider. Who knows what I can do to fix this.
Reply 1 of 2, by aha2940
Saying that something "does not work" is not helpful. If you post the exact error you get, or what happens when you try to run the game using the voodoo 1 card, then you may get more replies.
Reply 2 of 2, by Pierre32
I recall this one being tricky.
Carmageddon Max Pack 3dfx problem in real DOS
Help getting some 3DFX DOS games to run
Have you installed the patch? Start with "carm3dfx.zip" - and there are other options linked in those threads.
Here's what my directory looks like. Game is launched with CARMAV.EXE:
34.46 KiB
You don't see Glide2x there because it's elsewhere in my path. This is it:
GLIDE2X.zip
142.02 KiB
37 downloads
