First post, by kingcake
I need the DOS drivers found here: http://www.vogonsdrivers.com/getfile.php?file … &menustate=37,0
The *problem* is that you need to run a windows installer to get access to the DOS drivers and I don't have access to a windows 3.1 machine.
I tried opening the *.Z files with 7zip but it said they were an invalid file format.
Any idea how I can extract the DOS software from this Windows installer package?
Reply 1 of 3, by mr.cat
FWIW unshield doesn't like to open them either (just tried it)
If you have access to a Linux machine, Wine can be used to run Setup.exe. But it most likely has to be launched with WINEARCH=win32 and perhaps the version must also be set to 3.1.
The version can be set via winecfg or with the command "winetricks -q settings win31".
