First post, by ali90taz
Description:
Hi folks,
In this topic I want to offer you a small but very useful software for retrocomputer lovers, I coded this software myself to read and write the floppy disk boot sector (MBR), the idea of programming this software came from the need to have a way to create a floppy disk that can boot an old computer without resorting to third-party tools like rufus and similar, because I want to have total control over the boot sector for who knows in the future create my own operating system, if someone here aspires to do the same, maybe this software can also be useful.
It is worth mentioning that the software is in beta, so don't be alarmed if you find small bugs, I will improve it soon and add support for hard disks, keep an eye out.
Thank you for visiting my topic, long live the old computers!
Technical information:
CRC32: 10541770
Compatible with: MSDOS and Windows 9X in real mode.
Included files: FBW.EXE
Usage information:
Place the FBW folder in the root of the C:\ disk and enter the directory.
The following commands are available:
FBW READ - Reads the boot sector of the floppy disk on drive 0 and saves it as BOOT.BIN, the generated file will be saved in the folder where the program was started.
FBW WRITE - writes any file named BOOT.BIN to the boot sector of the floppy disk on drive 0, the file must be 512 bytes long and must be in the same folder or directory as FBW.EXE
Credits:
Used in understanding the floppy disk and its structure: http://www.manmrk.net/tutorials/DOS/PSBOOK/book4/floppyd.htm
Books used to get information: Borland Turbo C 2.0 - Reference Guide
Development environment: Borland Turbo C 2.01, Fujitsu Lifebook 770tx, IBM PC DOS Version 7.00 and HEXIT for debug porpuses.
Source code:
If you are interested in the source code, send me a PM requesting it.
Reply 1 of 5, by Jo22
Thank you very much! ^^
Reply 4 of 5, by debs3759
I always use John Fine's partcopy.exe
Nice to see more options for the same task though 😀
Reply 5 of 5, by doshea
Nice! I'm accustomed to using Linux's dd command for transferring data to/from disk devices, so I wondered if any DOS ports were available that could do this. I would expect to be able to do something like dd if=a: of=bootsect.bin count=1 where if= and of= are the input and output files/devices respectively, and it defaults to copying 512-byte blocks so count=1 means it will only copy one sector instead of the whole disk.
uxutl23b.zip has a dd.exe which is documented in uxutl23a.zip (there are also some other .zip files with other utilities from the same author):
Some of the command support raw disks and floppies to a degree (cpio, dd). The filename for a raw disk is /dev/hdxy and /dev/fdx […]
The filename for a raw disk is /dev/hdxy and /dev/fdx for a floppy where x
is the unit number and y is the partition (numbered from 1, partition 0 is
the whole disk unit). Thus: dd=/dev/hd00 count=1 bs=512 of=x copies the
boot sector from unit 0 to file x.
However I had trouble reading the boot sector from a 720KB floppy under Bochs, which reported attempts to access invalid sector numbers. That might be because Bochs is reporting the drive as 1.44MB even though I think I told it it should be a 720KB drive, but that probably means this tool won't deal with a 720KB floppy in a real 1.44MB drive. It could read the boot sector from my emulated hard drive though.
gnufut21.zip has a dd.exe where you can use if=0:, 1:, etc. to access physical disks, and I was able to read the boot sector of a 720KB floppy in a 1.44MB drive under Bochs using this tool, but it couldn't seem to read from my hard drive.
fut312bx.zip and futi14bx.zip also provide dd implementations but they don't seem to have any raw disk access facilities.
Those files are all available under https://www.ibiblio.org/pub/micro/pc-stuff/freedos/gnuish/ or on the Simtel 20 for MS-DOS CD-ROM disc 2 from September 1997 (https://archive.org/details/cdrom-cdrom-simte … ember1997-disc2). Unfortunately source isn't available for the uxutl23*.zip implementation but the rest seem to have source available.
Hacking F-15 Strike Eagle III and DOSBox's debugger
