First post, by auron
just a quick question for everyone that played this game on period hardware in recent times, how was the performance? on my p3 1100/512mb pc100/ti4200/sblive!/98se setup i find that on for example with 5 difficult AIs game the early- and midgame plays just fine but in the endgame it starts to stutter a lot and interestingly sounds cut out even when there's nothing else happening on screen. checked system monitor and it's not paging when doing that so i believe it's indeed overloading the CPU which is curious as the machine is quite a bit faster than what was common around the game's release.
don't really recall having performance issues with this game back in the day but then again it's been 20 years. or since this is a patched TC add-on, maybe some update worsened performance along the way by improving pathfinding or something?
Reply 1 of 12, by Unknown_K
I play Age of Empires 2 Conquerors all the time online with 8 players at 1080P but I use a Q9550 and GTS250 .
If the game stutters only late game I would think all those AI and full population (do you have 200 pop?) are just hogging the CPU too much.
Reply 2 of 12, by auron
200 pop yes, but the stutters and little freezes already start creeping up when at 80 pop or so. i have tested this on some other hardware as well in recent times - pii 400 (strangely pretty similar performance from memory, so maybe an FSB bottleneck) and p200mmx (pretty bad right from the start and only 64mb ram made it even worse). the original p166/32mb ram minimal requirement is quite the joke.
the HD version is a different beast with running under d3d9 and all that, the original version was directdraw of course.
Reply 3 of 12, by Unknown_K
The HD version I am talking about is the original release that the people of Voobly.com added higher resolution to while playing online (still 2d sprites just higher resolutions).
Reply 4 of 12, by nd22
Age of empires 2 requires quite a strong CPU. Period correct ones are insufficient to run the game with high population cap. Even a Tualatin 1400s has trouble in this game. I play on my socket 462 machine and it runs fine with Barton 3200. with 7 enemy AI and 200 population cap.
Reply 5 of 12, by gerry
played the original on Duron 800 with 256mb and tnt2 card, no problems at 80 or so pop but can imagine with larger population and larger maps the cpu will end up as the bottleneck; it must be running a great many calculations for each entity, but shuttling all that info to and from memory would also potentially be another bottleneck. I'd imagine, in keeping with many RTS games, that if you ran it on a late P4 or even later you'd not notice the slowdown as much due to all round speedier systems.
I was always impressed with various RTS games being able to keep up with many units in action at once on single core modest Mhz CPUs, making it appear as if it was all happening at once in parallel
Reply 6 of 12, by auron
the game could well be reacting unusually strongly to FSB or memory speed - i don't know why else the pii 400 would have felt so similar in performance. and the performance issues are really little freezes instead of a more granular drop in performance, so along with those sound cutoffs, that's somewhat rare to see. unfortunate that there isn't a proper way to benchmark this.
i'd be curious to see this game running on a willamette, maybe this is one case where that thing could actually leverage its memory bandwidth.
Reply 7 of 12, by shamino
I suspect the abruptness of the freezups in this game is a result of the AI script processing. Certain events may trigger a flood of work not just to interpret the scripts but also because the script may decide to (for example) launch an attack with 100 units, triggering a sudden load of searching for those units and pathfinding all of them at once. There may also be cascade effects of 1 AI action triggering more AI actions.
This kind of behavior could explain the sudden and inconsistent choppiness.
I haven't played in a few years but I recall I still had issues with 200pop on a P3 866/133, but maybe I didn't on a Barton 2100/200. Never played it on a Tualatin.
Reply 8 of 12, by nd22
In Aoe2 I strongly suspect it is frequency above all else! Tested last night on 2 different systems: Barton 2500 - lowest Barton CPU - can handle a game with 200 population cap while Tualatin 1400s can not. I will do more tests tonight.
Reply 9 of 12, by auron
if you mean CPU frequency, i don't see how that comparison would especially support that notion - barton 2500 runs just 433mhz faster than tualatin 1400s but has 333mt/s FSB and ddr ram versus 133mhz FSB and i'm assuming just pc133 sdram on tualatin. granted athlon xp will probably have higher IPC than p3 too so that's another factor. make sure to have a savegame with huge armies for repeatable testing.
i dropped the FSB to 66mhz on my aforementioned setup and can say the stutters got quite a bit worse, but that's not a very meaningful test either. to test the FSB/memory influence the best possible way would be some i815 (or even BX if can get 133mhz stable, i suppose) and comparing 100/133mhz FSB versions of the same CPU speed. bit of a far-fetched setup, really, but there might be some options with multiplier shenanigans on the athlon side as well.
Reply 10 of 12, by nd22
That is a reason AMD used PR rating: most Athlon XP if not all had higher performance than P4 with the same frequency with which they were compared against !
Reply 11 of 12, by nd22
I tested over the weekend with 3 more CPU's: Athlon XP 2600 Thoroughbred FSB 266 and Athlon XP 2700 Thoroughbred FSB 333. Both are running just fine with 200 population cap. Last processor tested was Athlon XP 1500 Palomino: severe stutters that made Aoe2 unplayable. The threshold for play-ability must be somewhere in between!
