First post, by GeneralDisorder
I have the retail CD of Noctropolis. Installs no problem from CD. Mouse works in the install program, etc. Sound card is detected no problem. Have tried with both mouse and sound disabled and no drivers loaded as well. Have tried multiple CD drives, multiple versions of MSCDEX as well as SHSUCD with the ISO loaded as a virtual drive.
No matter what I do when I run dark.exe or darkrun.exe the game displays and ankh symbol and then exits with the message "program terminated normally". If I run dark.exe it changes the display mode, displays the ankh symbol momentarily then switches the display mode back and exits. If I run darkrun.exe it changes the display mode then exits without changing it back and you can still run DOS commands and see a tiny command prompt that's repeated about 6 times across the bottom of the screen - seems that this executable doesn't restore the display mode like dark.exe does.
System specs:
PC Chips M912 V1.7 Socket 3 motherboard.
Intel 486DX4-100 w/heatsink & fan.
64MB (2x32 72 pin) memory.
ATI Mach32 VLB 2MB video.
Trident TVGA8900D ISA video.
OAK technology ISA video.
SB Vibra 16 ISA sound.
DOS 6.22
System plays Duke 3D, Shadow Warrior, Blood, Doom, etc no problems and perfectly stable.
I have used both the ATI (with the Mach32), UNIVBE and Scitech DD drivers with all three of the video cards I have with essentially the same results.
I noticed that the game seems to seek the CD drive before exiting which is why I have tried so many combos of drives and virtual drives.
I have it up to about 624k of free conventional memory. I have the EMM386 setup exactly as in the game manual, etc.
Running out of ideas!
GD
Reply 3 of 5, by GeneralDisorder
Tried it with a Biostar motherboard also using the UMC498F chipset and get pretty much the same behavior. The PC Chips board isn't one of the fake cache units and runs everything else just fine. I think it's just an issue with this particular chipset.
GD
Reply 4 of 5, by tabm0de
I dont want to be that one but it is kinda funny that in the user manual it says:
"My game says "program terminated normally" after i installed, or when i exit the game, is that bad?
- Nope, it just means that your system was working fine when you exited to dos.
naa, nothing yet...
Reply 5 of 5, by tabm0de
It could be work trying to remove the soundcard from the computer and try to start the game, games can still find sound cards even if no drivers are loaded.
And you might want to check the manual and just test everything they recommend:
https://www.google.com/search?q=Noctropolis+p … sclient=gws-wiz
The manual should be on top "Noctropolis – Install Guide - Pix's Origin Adventures"
naa, nothing yet...
