First post, by athlon_p0wer
- Newbie
I am using PC DOS 7 on my 486, and have looked a little bit into modifying my autoexec.bat and config.sys files. Normally, I edit these anyways to get CD support, and when I install my sound card drivers. Here I'm talking about messing with EMM386, and whatever other tweaks I can apply that will help with performance and compatibility. For example, I believe Adlib Tracker II will only run with EMM386 enabled.
I've searched around on the internet a lot, but have been given more questions than answers. I am good with using DOS at a basic level, but the more advanced stuff has got me tripped up.
Note that I will not be using Windows 3.1 because the video drivers for my VLB card take up memory from DOS as they have to load applications before you even use Windows.
Specs:
486 DX2-66
128KB L2 @ 15ns
16MB RAM @ 60ns
Cirrus Logic CL-5430 VLB
Soundblaster Vibra 16S
1GB Seagate Medalist IDE
CD-ROM
[EDIT]
I feel like I should note that EMM386.EXE comes with PC-DOS, and also that a version of SMARTDRV comes with it as well.
