First post, by devilish
Hi
I bought a copy of this for practically nothing on ebay. Except as i'd expect, age and everything... installing from the floppy is impossible.
But it gets more complicated.
On a modern machine (USB Floppy Drive) it doesn't read at all. On Dosbox, and mounting an A: drive there, the installation completes, but the folder is on the mounted C: drive, but there's no files in it at all.
On my Win98SE system, the disc reads no problem at all, but says "maximum installations reached" which I haven't seen before.
If anyone has a copy, can they verify the files that WOULD be on the floppy? as i'm a bit suspicious as it looks like something's missing, but could be wrong.
all I can see is:
install.bat
install.sys
pkunzip executeable.
Is this correct, and is there/not a workaround? (I know I can download it, etc etc).
Thanks
