First post, by Muz
Terra Nova have some coloring issue in Toshiba Satellite 225CDS running Windows 98, what should I do?
104.75 KiB
117.54 KiB
Reply 1 of 2, by Hezus
If you're running it straight out of Windows 98, then exit Windows first and run it from the DOS prompt. This might help.
If I recall correctly, Terra Nova uses UNIVBE, so take a look here and try one of the solutions there.
Visit my YT Channel!
Reply 2 of 2, by Muz
If I turn UNIVBE off, the video and the game runs well, but the color for the menu, navigation are like 16-bit, like the above.
Okay, I've run the UNIVBE from the downloaded link, now when the screen is at 320 x 200, the screen looks like a vertical glass, but for 320 x 400, the screen looks normal.
100.95 KiB
111.68 KiB
110.62 KiB
