Win98se Custom without Ramdrive vs ?
First post, by GabrielKnight123
Is there a difference from the ..custom.. 98se No Ram Drive boot disk as to the non custom when installing Dos 7.1 as the only OS on a hard drive? I found a download link for the custom version but its not working and I cant find it elsewhere so I have a 98se no ram drive boot disk which didn't say custom in the link would there be reasons to use the custom over the just no ram drive? Its just for games on a Pentium 4 3GHz with an Aureal Vortex 2 PCI, Ive tried the CD install version of Dos 7.1 with all the extras but there was parts of the autoexec.bat for automatically parking the hard drive that I couldn't disable with REM that slowed reads from a DIR command for some reason so I'd like to use a 98se boot disk to install 7.1
Reply 1 of 2, by GabrielKnight123
One more question I'm getting a password request when I try to extract the PAK files from the CD downloaded from REMOVED location CD Drive:\DOS71\DOS71_1S.PAK and DOS71_2S.PAK using both 7zip or Winrar
