First post, by feipoa
- l33t++
Is there any way to pass config.sys lines along when I run Safe Mode for Windows 95? For my particular IBM BL3 system, I need to run himem.sys with the /Machine:1 flag, otherwise himem won't load. If himem doesn't load, then Safe Mode won't load. By default, Safe Mode runs himem.sys without any flags, but I'm not sure which config file or registry entry it is running. I need to let Safe Mode know that I must run himem.sys with the /Machine:1 setting. Any ideas? Thanks.
