First post, by stanwebber
my systems freeze when i try to load either umbpci.sys or hiram.exe and i don't understand why.
first, umbpci which has considerably more documentation...my amd k7 system should be supported as it is chipset independent. umbpci correctly identifies my cpu as supported and installs itself, but then it just locks up. the only thing i can identify as a potential conflict are these bios settings:
Video BIOS Shadow
Setting to enabled, the video BIOS will be copied to the system memory and increase the video speed accordingly.
C8000-CBFFF/CC000-CFFFF/D0000-D3FFF/D4000-D7FFF/D8000-DBFFF/DC000-DFFFF Shadow
Setting to enabled, the extended ROM data located at the respective address range will be copied to system memory.
i sort of understand the video bios setting, but the other one is nonsensical to me. um, do want to cache system memory in other parts of the exact same system memory to improve performance? what should these items be set to?
second, i don't grasp how to use hiram.exe at all. am i supposed to load this with himem.sys or what? and in which order? is it supposed to provide umb's in real dos mode like umbpci? the documentation available is threadbare. i'd like to use hiram.exe on a pentium system without a pci bus, but it locks up this and my k7 system instantly as well. can someone show me a working example?
third, does anyone know if the xmgr or himemx alternatives load themselves (partially) high by default or do they always reside totally in conventional memory like himem.sys?
