First post, by Aebtdom
I have a voodoo2 SLI setup with a TRIO3D card for 2d gaming.
I start GTAFX the game starts to menu, but when I start the map, It returns with the message: What 3DFX card?
See screenshot.
The attachment 20220604_213712.jpg is no longer available
I put GLIDE2X.ovl in the gta and the gtados folder just to be sure.
What am I missing?
The attachment 20220604_214217.jpg is no longer available
Builds:
Xp3000+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
P2 350mhz + Diamond Viper V550 + 3Dfx Voodoo 2 12MB + AWE64 + 128MB SDR @ msdos / win98.
Reply 1 of 3, by Gmlb256
I see that you haven't got replies yet. Did you make sure that you used the correct GLIDE2X.OVL file that comes with the Voodoo2 driver?
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
Reply 2 of 3, by Aebtdom
I can take another look at that, I have copied the file straight from the C:\windows directory in to the game folder.
Builds:
Reply 3 of 3, by Aebtdom
Well, I have found a partial solution.
I had the cards in SLI, but it is a mismatched setup.
And apparently MS-DOS ain't to happy about that idea. Unless there are mismatched drivers for ms-dos, I will have to go and fly solo.
The attachment 20220605_215750.jpg is no longer available
The attachment 20220605_215818.jpg is no longer available
Builds:
