First post, by Nemo1985
So i'm playing with my 486 build and after some weird crash just after wolfenstein 3d was started (sound crippled and then the system hanged), after some troubleshooting with config.sys and autoexec.bat to be sure it was my fault.
I changed my config.sys file from emm386 to jemmex, then the system worked like a charme.
Then I noticed a weird thing (since i'm still on configuring stuff so I frequently reboot, with the very same autoexec.bat and config.sys, same bios options (I neither entered in it), here is what happened:
First reboot:
Jemm v5.83 [12/04/22]
System memory found at c100-c7ff, region might be in use
System memory found at e000-ffff, region might be in use
Second reboot:
System memory found at e000-f3ff, region might be in use
System memory found at f400-ffff, region might be in use
Doing some simple mat here is what I found:
First reboot: FFFF-E000= 1FFF (dec 8191)
Second reboot:
F3FF-E000= 13FF (dec 5119)
FFFF-F400= BFF (dec 3071)
13FF+BFF= 1FFE (dec 8190)
So there is a difference of 1 bit\byte (I don't know which one) between those 2 results.
Is it normal a normal behaviour?
Any guess?
Reply 1 of 3, by pentiumspeed
Did you also attempted cold boot several times in a row to see if this stays the same? This is part of doing a complete diagnosis and investigation.
Warm reboot is Ctrl + Ins + Del. Pressing reset button or toggling off wait a moment then back on that power switch on is considered cold boot.
On ATX PSU you have to press and hold 5 seconds to turn off if you are in DOS mode.
Cheers,
Great Northern aka Canada.
