Yoghoo wrote on 2023-03-06, 11:17:
kergoth wrote on 2023-03-06, 04:35:
kergoth wrote on 2023-03-06, 04:11:
There's one other option I've found in looking into this same thing, the "Autocon" tool which allows for switching between sets of config.sys+autoexec.bat and rebooting to the selected set also has a mode where it generates a menu configuration, where it uses the included menu.ctl config.sys driver. It seems to function similarly to boot.sys. I haven't done a full comparison of features, but it's worth trying out.
MULTICNF.SYS also seems similar, but its documentation doesn't indicate any awareness of loading dos high, which is a potential concern with that one.
Thanks! Will try Autocon. Unfortunately can't find MULTICNF.SYS. Do you have a link?
Also found out about Bootcon from Modular Software Systems which seems very nice. But can't find a download link. If someone has one please let me know.
Multicnf.sys is in multc21e.zip. Other similar tools seem to be: boots2a.zip, fasts101.zip, maus-sys.zip, mcf100.zip, minuet300.zip, rfcfg32.zip, select.zip. There are others that only give a menu in the autoexec, not the config.sys, but that's of limited usefulness unless you dive into dynamic device driver loaders.
Haven't managed to track down bootcon or cmenu.sys yet.
The 'bootutil' folder at a Simtel mirror, i.e. https://ftp.sunet.se/mirror/archive/ftp.sunet … msdos/bootutil/ haș a number of tools for a boot menu, though none really seem as capable as boot.sys, some may prefer a simpler option, or it may be worth it to avoid the shareware messages. Other similar resources include a Garbo mirror or cd (i.e. http://www.retroarchive.org/cdrom/garbo_dos/b … util/index.html), old simtel or other shareware cds, etc.
