First post, by xbit
- Newbie
I was installing a sound blaster card and the install crashed. When rebooting it get a "There is not enough memory to load the registry" error. Win95 will load fine and I don't see any issues.
Rebooted again > pressed F8 and did a step by step and created a bootlog.txt and it has the following errors. I restored a backup reg but i think because i can boot into win95 ok it also has this issue. Any hopes to fix or would a reinstall be the best option?
The X-Bit BBS @ https://x-bit.org/info
