First post, by Gahhhrrrlic
Having a problem I honestly didn't anticipate.
I had drives C, D and E, C being the OS obviously. I wanted to reformat the machine so I figured I'd put all my setup files and drivers and everything in E, format C and then I could load everything back from E
So I blew away C and put DOS on it and now I can only see the C and D drives. I can't see E for some reason. I didn't anticipate this because I figured in a DOS environment, why should the visibility of E have anything to do with whether windows is on it or whatever. Unless DOS is somehow different now. I dunno.
Does anyone know why I wouldn't be able to see this other drive and what I can do now to regain access to it? Is there something I have to do in FDISK for example? Right now FDISK doesn't show it at all. Just shows D.
