First post, by keenerb
Like most time-consuming retro computing projects it started off with some idle time and a pretty bad idea. Basically I found myself sitting on a three hour conference call in my man cave wishing I could use the Tandy 1000 sitting on my desk as my primary office machine. I started tinkering with a handful of DOS productivity suites like Deskmate, Spinnaker Eight in One, PFS First Choice, Geoworks, and maybe a few others I don't recall.
I quickly found myself focusing on Works. It's actually a pretty decent piece of software, commands/hotkeys are pretty close to modern Windows app design, and having multiple windows seemed pretty useful. Basic spreadsheets are very usable, formulas are largely compatible with Google Sheets/Excel, and the macro system is quite good. There's no spreadsheet tabs support but for doing the family budget, calculating retirement, etc. it's perfect. So I proceeded with a test migration of a few of my Google docs to Works...
The word processor imported a sample of exported RTF google docs with very little issues, although the proportional fonts vs. fixed-width fonts did cause me to clear up a few line wrap issues, but generally it was automatically handled perfectly well. The spreadsheet imported the CSV files fine but lost the formulas.
My next thought was "Hm, it'd be nice if I could access the same documents from my 486 with VGA too." I have etherdfs setup so that both the Tandy and my 486 system have an F: drive mapped to the same network share. I created a Document folder on that network share, created a batch file on each system that changes to f:\document and then launches c:\works\works.exe. Viola, each system boots up into an identical environment with the same documents available under File/Open. That's nice, now I can edit big spreadsheets in 80x50 mode rather than 80x25 on Tandy.
Now I was left with the question of accessing the documents from other, non-MSDOS machines on my local network. That ended up a trivial task, I created an SMB share to the Documents drive and used Dosbox-X to map an F: drive identically to the two physical DOS machines. Now I can update my budget.wks and home inventory from my Windows 11 laptop! Excellent!
I also recalled from an old, old project that I once found a dos emulator that could run non-graphical MSDOS apps in a putty session. After a little refreshing my memory and a fair amount of google searching I discovered DOSEMU/DOSEMU2 support this, so after a quick download and compile of DOSEMU2 I now have the capability to SSH into a raspberry pi and have an almost identical Works experience that I have on my physical machines, including running on my phone if I were desperate enough. This unexpectedly gave me copy/paste support from my modern windows machines to the Works instance, which made updating my spreadsheet formulas very very easy.
At this point I became concerned about interoperability. I mean, let's go totally crazy and think I actually start using this old-ass MSDOS system to hold important information, how in the hell would my wife ever find it or figure out how to access it if I got hit by a bus? I have a folder on my file server syncing to Google Drive so I simply redirected the F: drive on all three machines to a new share on that Google drive folder, and viola I have wks, wps, wdb files syncing to Google WITH change history tracking/version tracking. That's pretty spiffy.
Now I faced a tough question, can anything even OPEN these old Word files? Yes, actually. LibreOffice opens the files just fine, including all formulas AND charts in worksheets, and with formatting intact. What it CAN'T do, is save the files back in the Works 3.0 format, sadly, or it would be perfect, but giving loved ones the ability to read my old files and save as a modern format is probably good enough in the event that I kick the bucket unexpectedly I suppose?
As a failsafe, I found that the save dialogs in MS Works all include a text output as the second save format option. For database and spreadsheet it is a CSV file, for documents it's just a plain text file. I mentioned previously that the Works macro system is VERY VERY useful, and I mapped Ctrl-S to save the local copy, then File/Save As, select the second format, and save as a plain text file in the same Google Drive-synced folder. Google Drive lets me natively view the plain text files without any conversion required, so I think that pretty much covers the last of the bases.
So now I can access MS Works 3.0 and my documents from anywhere as easily as I access my Google Drive documents, plus they sync to the cloud and have version history/recoverability in the event I screw something up. I'm actually really pleased with how well this all works. I might see if I can get the windows version of Works running on Windows 11 and on my PII Windows 95 machine just to complete the experience...
Reply 1 of 6, by doshea
Nice! Although I'm disappointed it's just Google Drive and not Google Docs with some automatic conversion 😁
keenerb wrote on 2023-04-28, 16:42:
In case anyone is interested, Qemu can also do this if you provide the command-line option -display curses. In older versions it didn't deal with code pages well (non-ASCII characters might show up wrong), but in more recent versions (e.g. 6.1) it assumes the emulated machine is using code page 437 and does some translation or something. I have no idea if you can have emulated mouse in this mode (or whether DOSEMU supports that either).
Reply 3 of 6, by Tiido
Hahahaha, this is excellent ~
Reply 4 of 6, by chinny22
Since working from home became more common I think many of us have thought about swapping current day machines or at least some software with something older.
I toyed with the idea of an XP or even Win7 machine but other software like VPN and management software reports back to big brother who would not be impressed with my antics.
Office is the other big annoyance The currant version constantly pushing Office 365 "enhanced experience" on you, but then this is where most work files live. Plus 365's "exchange" server dropping support for older versions of Outlook. So guess I'm stick with these new versions.
Even still I love what you have done. I find it funny you went with Works 3 though. This is what I used with our first PC, It was perfectly fine for us at the time and even have it installed on my Win3x PC for Nostalgia. However never thought I'd go back to Works after our next PC came with Office 97 with its spell/grammar check while typing and using defacto file types.
Yet this is exactly what you have done!
Reply 6 of 6, by Pierre32
chinny22 wrote on 2023-05-02, 12:01:
I had plans to integrate my Roland SC-D70 into my work from home setup. As an audio interface for conferencing and a MIDI module for office ambience it was too perfect. Sadly I moved to a new work issued laptop and the plan never came together!
