First post, by Harry Potter
Hi! I have a library for the cc65 compiler called CBMSimpleIO. cc65 is a C compiler that runs on modern computers but targets some 8-bit computers. CBMSimpleIO is a replacement for some of standard C's text I/O functions such as printf() that is much more efficient. It does this by interfacing with the OS directly rather than doing a lot of extra processing. Now, I'm wondering if I should port it to some DOS-target C compilers. If so, I need to know how to handle assembler-based __fastcall functions. I also want to be able to print longs and unsigned longs. In order to do this, on 16-bit computers, I usually need to do extra work. On the 8086 and 286, how do I perform the 32-bit divide by 10 needed to convert to decimal/ANSI?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 1 of 4, by BloodyCactus
hmm well what do you call "more efficient" watcom already has assembler for 64bit multiply + divide of uint32_t.. and it works on 8086 too... and in 32bit watcom I dont see the point of trying to optimise printf.
unlike 8bit home machines like the c64, the pc doesnt really have routines in rom per-se, it as the bios and really only uses the disk int13h stuff....
Reply 3 of 4, by jakethompson1
On 8086, you can divide a 32-bit quantity in DX:AX by a 16-bit quantity, but only if both the remainder and quotient both fit in 16 bits (otherwise it triggers an exception).
You might read up on how compilers might optimize a divide by 5, from which you could derive divide (and remainder) by 10: https://stackoverflow.com/questions/41183935/ … ng-integer-divi
Reply 4 of 4, by Jo22
Why don't just use x87? The poor fellows without an NPU can run EMUL87.
