First post, by oh2ftu
Hello there.
I've installed a computer as follows:
- Soltek SL-54U5 motherboard (512kB cache) that has been recapped (at least the big ones)
- Amd K6-2/500 CPU
- 256MB+128MB RAM
- GF FX5500 (perhaps a little overkill?)
- Intel pro/100S PCI NIC (slot 2)
- Lexar 1066 32GB CF card in a generic chinese straight-to-MB adapter. This had to be manually defined in bios, even though I'm running the latest available vanilla BIOS (with award v4.51 core).
-- This has been partitioned at 2GB for windows and the rest for storage
As for drivers, I've installed:
- Via 4in1 v4.35
- Nvidia 81.98 (I tried 45.23 and 53.04 but they didn't recognize the card)
So the problem is as follows, if I try to download from an FTP with FileZilla it will hang the system for a while. It downloads at about 3-4MB/s.
Using IE or just "ftp" are not as bad.
Is there an issue with the CF card or some drivers? The CF card does NOT have the fixed bit set - I haven't found tools to do so.
Some transactions are really fast, while others may be very slow. For example, installing Unreal Tournament (GOTY edition) was very slow.
Any ideas?
