doshea wrote on 2023-07-09, 06:07:
As for DOS, a comment on https://hackaday.com/2020/02/09/c-the-languag … s-3-11-and-dos/ suggested that the .NET code wasn't really being translated to native DOS code but rather something which required https://github.com/Baron-von-Riedesel/Dos64-stub ('small stub that allows to run "bare" 64-bit PE binaries in DOS', I guess it's like HX DOS Extender).
A stub? I see parallels to OS/2 and "Family Mode" programs using "Family API".
These essentially were OS/2 programs with a built-in OS/2 runtime.
They could natively under OS/2, but also more or less under plain DOS.
https://www.landley.net/history/mirror/os2/hi … s213/index.html
https://www.os2museum.com/wp/os2-history/os2-1-0/
https://osfree.org/doku/en:docs:os2:api🎻
That reminds me a bit of Windows 3.1/DOS hybrid EXEs (Windows Setup) or Carbon applications on Power PC Macs, too.
Edit: If you enjoy doing a bit of Windows 3.x development, please have a look at MS Quick C for Windows 1.0. .
It's a cute little compiler that runs completely on Windows 3.x and doesn't require DOS environment variables to be set up etc.
If you have tinkered with DOS-based 16-Bit Windows SDK before, you may remember how messy this can be at times.
Quick C also can create similar pseudo-textmode applications like Turbo Pascal for Windows can.
They helped at making DOS-based source code run on Windows without much alteration.
To do so, they simulated MS-DOS prompt (inverse colour).
The resulting programs are essentially MS-DOS look-alikes running on Windows 3.x.
Edit: It just comes to mind because the C programming handbook my father has in his book shelve mentioed MS Quick C for Windows.
