Nexxen wrote on 2023-07-15, 10:09:
You could try reinstalling W98 on another HDD to check if it wasn't just a corrupted file.
Might be faster than pinpointing the real problem.
I originally installed 98Lite because normal Windows 98 is slow on a 66 MHz 486 PC. It worked great; navigation was as fast or faster than Windows 95 on the same PC (I selected the option to replace 98's bloated, web-integrated Explorer with the standard Explorer from Windows 95, which is what makes most of the difference). The only problem I had with its refusal to restart.
In order to find out whether or not the restart problem was caused by 98Lite modifications, I formatted C: and installed the normal, full Windows 98 SE, and it had the exact same restart problem as 98Lite did. Then I formatted again and installed the normal, full Windows 98 FE, and it had the same restart problem as SE. However, I tried one of the common suggestions for Windown 98 shutdown/restart problems, which is to disable fast shutdown (msconfig.exe > general tab > advanced), and that actually worked, which is surprising because disabling fast shutdown did not fix the restart problem on 98 SE.
So for now everything is working perfectly. Disabling fast shutdown solved the restart problem in 98 FE and neither version of Windows 98 has had the vanishing NIC and/or sound card issue that Windows 95 had on my PC.
