First post, by iulianv
- Member
Hello everyone,
I'm trying to figure out whether the set of floppy images found online as NC 5.51 really are NC 5.51, as there is no mention of "5.51" anywhere after installation. I'm thinking of the "Info" panel - mine says "Version 5.5", while one of the screenshots on Wikipedia shows "5.51" (date is the same, but I've read about this being a sign of version 5.51 being somehow "rushed").
I've also read that (or one of) the difference(s) between 5.5 and 5.51 is the support for long file names and the "Wide" panel option - I'm yet to install it in a Win95 virtual machine to test this.
But I installed what passes as version 5.5 online, for comparison - the "Info" panel is the same and both have the "Wide" panel option, but the sizes of the .EXE files differ by a few tens of bytes.
Does anyone know a way to tell for sure which version is which?
Thank you.
