First post, by batmreload
Trying to get wfw working, but setup freezes randomly. Tried to use an install that I allready had working on my 486,
but after starting, I get the dreaded MAIN.GRP is invalid or corrupt.
So far I've tried this on 2 systems:
Sis 530 chipset K6/2 500mhz machine, 128mb of ram, 20 gig disk (Ms-dos installed on 2.0gb partition)
440bx- descendant mobo (Abit Bx5, iirc) Pentium 3 500mhz , 256mb memory, 2gb ms-dos partition on another 20gb disk.
Anyone have any pointers? Maybe the cpu's are too fast?
Reply 1 of 6, by Jo22
Hi there! May I ask which version of DOS you're running?
As far as I know, Windows 3.1x likes MS-DOS 3.x to 6.22 most. PC-DOS, too.
Also, did you run SmartDrive? It should give some more abstraction to HDD access, maybe.
Windows 9x Setup even tries to load it automatic.
If that's not gonna work, you can try using a separate HDD driver for Windows 3.x.
The MicroHouse driver is okay, it can handle media up to 8GB.
http://win31.de/edrivers.htm
Also make sure that the VFAT and SHARE stuff isn't being loaded high in the DOS startup files.
WfW 3.11 uses Virtual FAT, but without long filenames.
Maybe it's also a memory issue. MemMaker might be able to help.
Or use QEMM 7 or better. 386-Max is worth a try, too, since a file of it is being part of Windows..
Anyway, these are just some ideas. I hope that the others have some, as well. 🙂
batmreload wrote on 2023-09-30, 15:50:
Unlikely, Windows 3.x is very forgiving here.
But still, you can try running Windows 3.1 in Standard-Mode (WIN /S). It should never fail.
Reply 2 of 6, by Gmlb256
Faster CPUs should never have problems with Windows 3.x.
How do you have set the 2GB partition on the 20GB HDD? FAT or FAT32? 32-bit file access enabled?
Reply 3 of 6, by Robbbert
I have a perfectly working installation on a 500MHz Celeron. I didn't set it up though, it came on a random hard drive that I acquired. All I had to do was install networking drivers, TCP/IP, video and sound drivers - the usual stuff when using different hardware.
Reply 4 of 6, by Cyberdyne
Use WfW 3.11 as a daily driver in a P3 800MHz. Never had any persistent problems. Use MS-DOS 6.22 and modified 7.10 with FAT32. Using even UMBPCI and HIRAM and never had any problems. Windows 3.1x is speed and memory friendly all the way.
Reply 5 of 6, by Robbbert
Just to be perverse, I tried my HD in a HP DX2000, which runs at 2.8GHz. After disabling the drivers for incompatible hardware, it started up ok.
So I don't think speed is going to be a problem - more likely is the hardware.
