Bernkastel7734 wrote on 2023-10-08, 05:47:
Just wonder, if the virus is dangerous for my WinXP computer that I'm using to make floppies.
Possible but unlikely, Windows NT has a synthetic DOS that doesn't allow direct manipulation of the FAT, for example.
Or direct access to a HDD via BIOS (int13h).
And even if it did, the Windows XP PC uses FAT32 or NTFS format.
To be a treat, the virus would need to be well behaved and use the normal MS-DOS API (int21h).
But since it runs on an MS-DOS compatible PC, that may or may not the case. I seriously can't make a promise here.
Back in the day, resident anti-virus guards (TSRs in background) would have stopped the virus if it attempted an file access, though.
Which means that they normally showed a strange behavior that's unusual to an ordinary MS-DOS application.
Hm. So it's hard to say. Without knowing about the internals of the virus.
If your want to be on the safe side, you can try running Virtual PC 2007 and give it exclusive access to the physical floppy drive.
That way, you can run an imaging software inside a virtual machine.
Or use VirtualBox. It can take control of USB devices.
So an USB floppy drive can be exclusively mounted inside a virtual machine (if the Guest OS has USB floppy support).
For DOS, there's DCF, Disc Copy Fast.
For Windows 3.1, there's WinImage v3.
For Linux, there's rawrite.
Windows 9x is a bit dangerous to original disks, because it does modify the boot sectors of unprotected floppies.
https://www.os2museum.com/wp/the-ihc-damage/
