First post, by another_808286
As I understand, the most recent arache versions (https://www.glennmcc.org/arachne/) are provided either optimised for a 387 system, or general purpose one for the 8086. I have a 286 system with an FPU and am curious to see if there would be much of a performance difference using the FPU and maybe taking advantage of a few of the instructions available on the 286 but not 8086. The sourcecode is available but I don't see a clear way to compile it for 287 and I was wondering if anybody has experience with doing this in the past or may know of how to do it. I can understand a certain amount of code, but don't really know stuff like the structure of large multi-file codebases, so I am a bit confused by Arachne's code.
Reply 1 of 3, by Jo22
Hi. I had a similar problem last year.
Reply 2 of 3, by another_808286
Jo22 wrote on 2023-10-13, 05:14:
Ah, this is great, I see someone went ahead and recompiled the files:) Vielen Dank!
I notice the one who recompiled said that they weren't sure if the TCP/IP stack still worked, did you find that out?
