First post, by Try_deleted
I'm trying to find out how to use mods and wads on doom II on an Windows 2000 pc, is it possible?
Doom95 should work on Windows 2000, with a mouse fix:
https://doomwiki.org/wiki/Doom95
If you want something more than vanilla compatibility, check the list of Windows-compatible ports here, then find which of them have Win2000-compatible versions (probably older releases):
https://doomwiki.org/wiki/Comparison_of_source_ports
For mods you'll likely want a zdoom port
Windows 2000 compatible doom ports:
*If you use BWC you can use XP+ compatible ports but those using SDL2 may have issues with mouse input. It's been a couple of years since I last tried.
ZDoom_CL_2.1.8
zdoom 2.8.1
gzdoom 1.8.04
Zdoom LE 2.8.3a
zdoom32 2.8.6
Chocolate Doom 2.3.0
Crispy Doom 3.2
Rude 2.5.0c
Eternity 3.40.37
Vavoom 1.33
prboom plus 2.5.1.4
Doomsday 1.9.0 beta 6.2
zdaemon 11021
DelphiDoom 2.0.7.735
Doom Legacy 1.48.12
DoomXS 1.0.6.142
FPCDoom 1.14.18.134
