First post, by GloriousCow
Just linking my announcement on VCF here for visibility.
https://forum.vcfed.org/index.php?threads/win … r-8088.1245597/
MartyPC: A cycle-accurate IBM PC/XT emulator | https://github.com/dbalsom/martypc
Reply 1 of 2, by Grzyb
So, original drivers for both EGA and VGA use 186+ instructions...
in this case I expect the 8514/A driver to do that as well...
I was recently thinking about running 8514/A with 8088 - Re: Should a Diamond Speedstar Pro (CL-GD5426) work in Win3.1 in 286 real-mode?
but it seems the driver would require patching...
anyway, first thing to do is check whether ATI mach8 (or some other 8514/A clone) actually works with 8-bit ISA.
Żywotwór planetarny, jego gnijące błoto, jest świtem egzystencji, fazą wstępną, i wyłoni się z krwawych ciastomózgowych miedź miłująca...
Reply 2 of 2, by Jo22
Thank you! The patch is very handy for owners of Amstrad/Schneider PC1640, for example.
That's an 8086 PC with integrated EGA graphics.
