First post, by TheMLGladiator
I'm having an issue getting this game to work correctly on my Voodoo 2. I'm having identical issues to this person: https://keeperklan.com/threads/2736-Very-low- … PS-in-Main-Menu. Basically, the main menu slow when the menu options are on the screen, but not when it is moving. Also there are some text glitches with my Voodoo 2. It looks similar to the artifacts on the Voodoo 3 PCI running DOS games, but it only seems to happen when the Voodoo 2 is displaying 2d content. This also happens during the opening cutscenes in Lego Island.
Video of issue: https://streamable.com/wtlgzm
System Specs:
Windows 98SE
Pentium III 850 MHz
Asus P3B-F 100 MHz FSB
Geforce2 MX
Diamond Monster 3D II
Sound Blaster AWE 64 / Sound Blaster Live!
Reply 3 of 10, by The Serpent Rider
The menu has very heavy alpha effects, which can kill performance even on much faster cards.
Reply 4 of 10, by leileilol
i'd think the menu is more choking the voodoo2 on buffer writes than anything else it's doing for 3d (and this would be worse for SLI - V2 memory is slow and the extra card means double penalty). IIRC a fresh DK2 install would prepare the config for a simpler menu without transitions
Reply 5 of 10, by TheMLGladiator
leileilol wrote on 2023-12-18, 02:47:
That's what I was thinking, because the slowdown only occurs when the menus are drawn, not when the menu is transitioning.
I'm a bit confused about this part, is this just to clear any changes I have made from default? Was there a setting for the simple menu in the installer?
Also, I'm a bit worried that my Voodoo 2 is having issues with buffer writes, because there are some weird horizontal artifacts around the 2d elements of the main menu.
Reply 6 of 10, by leileilol
TheMLGladiator wrote on 2023-12-19, 01:13:
If they're purple artifacts that are 4 pixels wide and such, that's normal. This is the video filter feature
Reply 7 of 10, by TheMLGladiator
Got the game to use my primary adapter (Geforce2 MX) by removing the V2 drivers and reinstalling the game. The menu slowdown persists, so I'm going to assume this holds true for vanilla 1.51 regardless of which card is used.
leileilol wrote on 2023-12-19, 01:40:
It's more like the glitch in the video I linked in my original post, but not as extreme. I'll update my post with a video soon.
Reply 9 of 10, by akula65
The old EA DK2 support page may be useful.
If you click the link for the FAQ page, you will find (among other things):
How do I force DK2 to use a different video card?
You can force DK2 to use a different video mode using the command line switch -DDD <value>
The number that replaces <value> selects the direct draw device. If you have 2 3D cards then you will have three direct draw devices - Software Mode, 3D card #1, 3D card #2. Depending on how Windows has configured these cards, you can select them by using -DDD 0, -DDD 1, -DDD 2 or -DDD 3.
So you don't have to go to such extreme lengths to switch video cards in your testing.
The link for the Troubleshooting page may also be of interest. The DK2 devs seem to have believed that the vast majority of issues in the game were due to driver issues, although there is some indication that particular hardware was to blame in a small number of cases (particular motherboards, etc.). There are some instructions for using the command line switches toward the bottom of this page.
