Recommended DOS file manager?
Reply 20 of 33, by froller
Jo22 wrote on 2024-02-09, 18:09:
More like task swapping, though, maybe. 🤷‍♂️
Cool! Never knew it can do this.
Nope, DN can't do such things. It is more like Norton Commander on steroids.
▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ 100%
Virus check complete. All viruses are working properly.
Reply 21 of 33, by analog_programmer
https://m.youtube.com/watch?v=tB035ZDMZD4
DOS Shell was pretty good DOS file manager, but m$ killed it intentionally in the sake of win3.xx.
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 22 of 33, by Harry Potter
I can back up some of the data to a USB drive and even have drivers that handle USB and LFNs. Maybe I'll do that the next time I'm at my mother's house. Thank you.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 23 of 33, by Harry Potter
Uhh...I want to compress the data backed up. What DOS-based compression utility can handle LFNs?
Reply 24 of 33, by George Razvan
froller wrote on 2024-02-09, 20:25:
I use X-Tree, mostly for nostalgic reasons. Version 2 has a lower memory footprint than 3.0. DOS Navigator is another one that is quite good. Norton Commander is installed on all my retro machines for it's excellent serial link connection. Maybe NC 4.0?
Pentium 75 MHz ,Intel Advanced /ML ,64 MB RAM ,Matrox Millennium II,160 GB 7200 RPM
Pentium Pro 200 MHz, Intel VS440FX,32 MB RAM, Elsa Gloria Synergy,40 GB 7200 RPM
Dual Pentium III 650 MHz,512 MB RAM,3 x 4.5 GB SCSI Quantum Viking II 7200 RPM
Reply 26 of 33, by Harry Potter
Uhh...where can I get it? Google gave me millions of unrelated results. 🙁
Reply 27 of 33, by Harry Potter
Never mind: I found it on REMOVED. Thank you for the tip. 😀
Reply 28 of 33, by Harry Potter
Before I look into it: does it support multi-tasking? BTW, I want my mother to use the computer as well, but she's not good with computers. 🙁 I asked her if she would use my laptops there, but she said she's afraid of breaking them. 🙁 I have Moo installed on it and set up for minimal use. I can add more.
Reply 29 of 33, by badmojo
You don't seem too comfortable with computers yourself there Harry - I'd suggest getting your mother an iPad. My mother loves hers.
Reply 30 of 33, by froller
Harry Potter wrote on 2024-02-11, 11:38:
Then just install Linux. Some of the latest KDE spins. They look and feel pretty much like Windows but it's harder to break them w/o root access.
If she doesn't need some kind of software that has not been ported yet she will not feel any difference.
Reply 31 of 33, by THEBaratusII
I recall using something like Norton Commander at one point, I think that's the one with the floppy disk screensaver if I'm correct. As for multitasking, I don't think DOS is designed for multitasking and even if there is, it probably isn't the best (correct me if I'm wrong.)
As for data, if it has anything important in it, I would definitely invest in using a adapter to get the data to a newer machine/harddisk. I can't stress this enough.
My Website
YouTube Channel
Reply 32 of 33, by Jo22
analog_programmer wrote on 2024-02-09, 21:40:
Hi, the history behind these things is really fascinating.
The DOS shell and the OS/2 and Windows task-switcher are related.
The task-swapper of the DOS Shell looks not too different to the one used in Windows 3.x Standard-Mode.
The inactive application is essentially freezed and swapped out of memory.
In OS/2 1.0 textmode, the shell's switcher mechanism existed, too.
It had the same gray "title bar" at the top of the screen, if memory serves.
Then there's MS-DOS Executive from Windows 1.x and 2.x, which resembles MS-DOS Shell a bit.
Or MS-DOS Manager 1.0 from the DOS 3.x days.
It essentially became the DOS Shell in DOS 4.
Edit: What's also cool about DOS Shell, it has similar colour schemes to Windows 3.x.
I liked emerald, for example. It also could use VGA text mode, to display custom icons not found in the DOS codepage (folder icon, scroll bar parts, drive icon etc).
Edit: I mean, you're right that Windows 3 killed DOS Shell.
In MS-DOS 4 and 5, the DOS Shell was meant to be the friendly face of the system.
When Windows 3.x was out, Microsoft began to bundle MS-DOS 5/6 and Windows.
That resulted in the popular WfW 3.11 with MS-DOS 6.2x bundles.
By that time, DOS Shell no longer was the default GUI by that point. Gratefully, it was available via the supplemental disks.
The English version, at least.
In order to get hold of a localized copy, MS-DOS 6.0 was needed.
It had all the supplemental disk files, but localized.
Edit: Hi, this is perhaps a bit off topic, but PC-Tools 7.x had a graphical desktop program using VGA text mode (a TUI rather than a GUI).
Including a few nice utilities. Calculator notepad, a terminal program, ASCII chart etc.
Reply 33 of 33, by analog_programmer
Jo22 wrote on 2024-02-14, 09:02:
Hi, the history behind these things is really fascinating. […]
Thanks for the details, Jo22. In the late '80s and early '90s I used m$-DOS 3.30 on some IBM-XT-clone 16 bit school computers, but I don't remember this "MS-DOS Manager 1.0" file manager. Maybe it's only available with some OEM DOS 3.xx versions. And actually PC-Tools (don't remember which version) was very convenient set of tools/utilities to be used with DOS 3.30.
P.S. Taking a broader (abstract) view of the DOS things, windows (for workgroups) 3.11 (up to "mistake edition" - including) is/has the best file manager for DOS 😀
