I can't get it to work on 86box since the SB mode freezes the game. I'm trying to figure out if it works on real hardware, and if so, what hardware and boot settings need to be used.
Has anyone managed to run this game on a Sound Blaster card?
What a coincidence, I just revisited this game last weekend.
It works for me as well with the Audician 32 clone (A220 I5 D1) in a 386/40.
Nothing special about the config, the usual generic himem, emm386, cdrom & mouse drivers, dos 6.22.
Largest executable program size 624K (638,912 bytes)
Largest free upper memory block 2K (1,776 bytes)
Available space in High Memory Area 5K (5,344 bytes)
MS-DOS is resident in the high memory area.
Thanks. It's more or less the same as mine.
Are you using only the windows' built-in driver for sound blaster, or installed a separate driver, perhaps for DOS?
Do you have any other files in the game folder (FIRE) besides FIRE.EXE and FIRE&ICE.CFG?
Just the config line and the programs to set up the environment variables, I'm not running windows. Yes I only have those two files in the DIR.
